  • Guests: 46
Calculating resonant capacitor values
Kiwihvguy
Sun Nov 06 2011, 02:21AM Print
Kiwihvguy Registered Member #3395 Joined: Thu Nov 04 2010, 08:42AM
I saw a thread somewhere else on 4hv about calculating the resonant capacitor value, involving the inductance of the transformer maybe? Correct me if I'm wrong.
Is it something like the reso cap value is half the inductance of the tranny? I'm not sure but I need clarification thanks.
Inducktion
Sun Nov 06 2011, 02:38AM
To find the value of a resonant capacitor, you'd need the inductance of the transformer, and the frequency you're looking for.
You can just google "Resonant frequency calculator" and it'll come up with several.
Kiwihvguy
Sun Nov 06 2011, 07:26AM
Inducktion wrote ...
"and the frequency you're looking for" - Isn't this the mains 50Hz in my case?
Are there any ways of calculating inductance if you don't have an inductance function on your DMM?
Ash Small
Sun Nov 06 2011, 11:04AM
Józef C wrote ...
There are, but the simplest way requires a signal generator and osilloscope.
You connect a capacitor of known value in parallel with the unknown inductance, you usually also connect a resistor in series with this circuit, then you connect the two ends to the sig. gen. and connect the 'scope across the capacitor/inductor, and adjust the sig. gen. until the amplitude indicated on the 'scope is at a maximum.
This is the resonant frequency of the inductor/capacitor. from here you can work out the inductance.
Kiwihvguy
Sun Nov 06 2011, 07:39PM
Sounds complicated. I don't even have a signal generator or a scope.
Turkey9
Sun Nov 06 2011, 10:58PM
If your transformer is running off mains, here is a simpler way to figure out inductance: Link2
