  • Guests: 37
01/13 si2030 (62)
MOSFET questions
HDF49
Sat Nov 05 2011, 08:18PM Print
HDF49 Registered Member #977 Joined: Thu Aug 30 2007, 06:57PM
I pulled apart an old monitor today, and along with the flyback I found a few irf630s and irf640s, I'm just wondering if they'll be ok to run in a zvs or 555 timer based flyback driver, and if any of you have experience with them?
Antonio
Sat Nov 05 2011, 09:33PM
These are 200 V transistors, with 9 A and 18 A maximum current. You can use them, but not with the original primary winding of the flyback, that requires the 1600 V transistor (usually bipolar) that you can find in the board too and other components around it, as a fast diode in parallel, a high-voltage capacitor to limit the collector voltage, a driving transformer, etc. The maximum current is somewhat low too.
Alex M
Sun Nov 06 2011, 12:37AM
You can, how ever it won't last too long before either the 555 or MOSFET goes pop (in my experience).
HDF49
Sun Nov 06 2011, 12:24PM
Thanks for the pointers, I think I'm going to make http://flybak.wap.sh/More_1 that with my irf640s, and order some irf250s for a mazilli driver as well. What do you think of that resonant driver?
Ash Small
Sun Nov 06 2011, 12:40PM
fight fire with fire wrote ...
That link doesn't appear to work.
HDF49
Sun Nov 06 2011, 02:49PM
Sorry, it's no2 here Link2 I'm also thinking about getting some irf540s, they seem cheap and powerful, will they work well with that driver?
