  • Guests: 44
A coupling problem?
Dosinski
Fri Nov 04 2011, 10:38PM Print
Dosinski Registered Member #2680 Joined: Wed Feb 10 2010, 09:23PM
I've been working on my DRSSTC and finally got it up and running. It uses cm300s and I have the OCD at 300A at the moment. With 200V on the primary, the streamers don't look like a nice lightning bolt shape, but more of a lightning bolt with a lot of streamers coming out of it. It makes a hissing sound that a tuned tesla coil does not. I've tried moving the tap all around on the primary, but the streamers get smaller, so I know i have the tap in the right place. Now i'm wondering if this can be caused by incorrect coupling. I tried raising the secondary, but the streamers get really short. Is there any easy way of moving the secondary down or do i have to redo my primary? Are my issues even caused by incorrect coupling?
Herr Zapp
Sat Nov 05 2011, 12:00AM
Dosinski -
What is your "calculated" coupling factor? (From JAVATC or other CAD tool)
Herr Zapp
Dosinski
Sat Nov 05 2011, 12:22AM
JAVATC estimates that the coupling factor is 0.2k
Gregory
Sat Nov 05 2011, 01:29PM
For a big DRSSTC this is a very high coupling. In my 12 foot spark tesla coil, that uses cm300 too, I have a coupling factor of 0.125. Is normal the strange streamers with low voltage. Even 400v my coil don't produce more than 1 foot but when the voltage rises up to 600v become something like +11 foot.
Dosinski
Sat Nov 05 2011, 08:14PM
My DRSSTC is only 4 feet tall (with the secondary windings only being 29 inches) with a resonant frequency of 65kHz
