  • Guests: 43
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
phasing
lokeycmos
Fri Nov 04 2011, 01:48AM Print
lokeycmos Registered Member #2553 Joined: Fri Dec 18 2009, 01:36PM
this just dawned on me tonite. are there any phasing considerations to take into factor with a tesa coil? by this i mean direction of turns on secondary, clockwise or counterclockwise on the primary, the way the transformer is connected? i know that AC doesnt have polarity, but why do the arcs come off the top and not the bottom at the same time if there is no polarity?
dude_500
Fri Nov 04 2011, 02:08AM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
Arcs do not come off the bottom because the bottom is connected to earth, thus there is not a large electric field created on the base required to ionize air. Polarity of the coil in general does not matter because the output polarity is irrelevant, and as you said, AC. Changing the winding direction will invert the voltage output with respect to primary current, but either way it's going to be an oscillating high voltage so you won't see any difference.
