  • Guests: 46
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Wanted; A Large SCR
Inducktion
Mon Oct 31 2011, 11:35PM Print
I need a large SCR... Stud, puck, module, anything. (tis for a coilgun)
PM me, or email me at **link**
We'll see how it goes from there. :)
Matt Edwards
Wed Nov 02 2011, 11:51PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Specs required?
Inducktion
Thu Nov 03 2011, 12:12AM
Needs to be able to handle +600 volts, around say, 2kA pulse.
Matt Edwards
Thu Nov 03 2011, 03:52PM
Believe the best I have is maybe 100A 1600V
Thu Nov 03 2011, 05:11PM
Oidium45 wrote ...
That might do the trick for Inducktion,
even in a conservative design, if its datasheet can be found.
Look for a single-pulse current rating, and its measurement condition (pulse width and shape).
Within limits, the current can go higher if the time is reduced by the square of the current factor.
Some SCR data sheets give an I^2.T rating, in A^2.s, which applies to the time integral of I^2.
(occasionally, but I think wrongly, called the action integral).
Note that the force in an inductive disk launcher,
or a reluctance coilgun without magnetic saturation, is proportional to I^2.
Inducktion
Fri Nov 04 2011, 01:01AM
I do agree, that sounds like it would work!
Matt Edwards
Fri Nov 04 2011, 04:28PM
I'll try to remember to look this weekend and send you some part numbers of what I have available. I'm not too familiar with QCW. Does it specifically need to be an SCR?
Inducktion
Fri Nov 04 2011, 04:29PM
Oidium45 wrote ...
An SCR is the best and most affordable option as a semiconductor switch in a coilgun. A really beefy IGBT would work too, but it would be considerably more expensive.
Matt Edwards
Fri Nov 04 2011, 05:34PM
Haha, I was varying between a few posts. Forgot this was for a coil gun. I don't suppose a triac would do the job?
Inducktion
Fri Nov 04 2011, 07:04PM
Oidium45 wrote ...
If the triac can handle the current values I stated above, then yes!
Edit;
So, I made my coil, and according to Barry's simulations, I should be getting a roughly 2kA pulse out of my coilgun, for a little under 8 mS.
