  • Guests: 32
OiD (38)
jolty (50)
Baran (29)
10/16 Sanchez (36)
10/16 Knarvel (13)
10/17 Madgyver (40)
Do mots typically have more aluminum primaries than copper?
Mon May 20 2013, 06:18PM
Yes, almost all MOTs are aluminum.
Reason - Cost.
You can buy a microwave oven at your local walmart for $50-100 bucks.
If the MOT was made out of copper winding, the copper itself would cost more than that.
Mon May 20 2013, 07:39PM
EasternVoltageResearch wrote ...
Reason - Cost.
Aren't those cheap ones all 'inverter topology'? They don't use MOT's anymore, due to cost.
Mon May 20 2013, 10:59PM
Ash Small wrote ...
Reason - Cost.
I second Ash's point.
Mon May 20 2013, 11:03PM
Ash Small wrote ...
Reason - Cost.
Maybe. I haven't opened up a microwave oven in probably at least 10 years. That would make sense however.
macona
Tue May 21 2013, 06:49AM
macona Registered Member #3272 Joined: Mon Oct 04 2010, 11:40PM
Aluminum is used because it is cheap and light. The increase in resistance is negligible especially in the secondary of a step down or the primary of a step up transformer. The resistance will build up on the HV secondary due to the sheer length of the wire.
Almost all welders have aluminum windings. They look like copper at first due to the enamel.
