  • Guests: 41
Flat panel TV repair
Sun Oct 30 2011, 08:33AM Print
Hi guys.
Just moved into a new flat (thanks GHA!) and need a TV.
I found a JVC 32" which was being thrown out for bad PSU, but the panel seems fine.
Luckily got to it before the nice people who remove these things smashed the screen...
Reckon there is any way to test then fix it for not too much wonga?
Its totally dead, no sign of life and no standby light..
Last time I hooked up 9 SMPS's in parallel to generate the 9 power rails it needed then
ordered a broken TV and asked for just the boards.
2+ years later, works well.
Kind regards, -A
#include "6EQUJ5.h"
Sun Oct 30 2011, 08:53PM
I have a view sonic which still works after i replaced the main filter caps on the SMPS, these viewsonics were notorious for blowing out these caps which were spec'ed poorly in ESR. Havent had a problem in 1+ year.
are you sure the PS isnt the problem?
Mon Oct 31 2011, 03:40AM
I would second the just replacing the filter caps, all of the dead monitors I have found (admittedly much smaller monitors) have had bulging caps which simply needed replacing.
I had one friend with a larger lcd panel (about the size of yours) which had a bad self start circuit on the psu,which was due to a shorted zener diode, which in turn took out a bridge rectifier. If you aren't getting anything out of it I would try and trace down the startup 'bootstrap' circuitry and look for issues. If you are feeling really brave you can try just feeding voltage directly into the supply rail for the switching circuitry as well. Any luck locating a service manual? The aforementioned TV actually had a complete schematic of the power supply in it smile
Mon Oct 31 2011, 03:49AM
... wrote ...
my caps were bulging, with one shredded open at the top, and a dead short. which then shorted out a normal diode and scorched a zener, replacing them fixed all psu related issues.... i used several smaller caps in parallel to get the ESR down, its a miracle they all still fit in there.
Mon Oct 31 2011, 08:30AM
Yeah, someone on #hvcomm suggested something similar.
The trick which sometimes works is to wind a 10 turn coil around the main SMPS transformer and connect this through a ballast capacitor (current limit) to a high wattage halogen supply of the SMPS variety.
This at least lets you get the thing going, so you can then find the shorted rail(s) and reduce the problem's complexity to manageable levels.
-A
