  • Guests: 47
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
How to increase the spark length of my tesla coil
Electrikid221MnM
Sat Oct 29 2011, 06:13PM Print
Electrikid221MnM Registered Member #4172 Joined: Sat Oct 29 2011, 05:57PM
Hi this is my first post onthe forums. I was wondering if there was a way to boost the spark length?
Sat Oct 29 2011, 06:28PM
Sorry but your question is too general. Please specify your coil type and details, performance, and what you have done to try to increase the spark length.
Electrikid221MnM
Sat Oct 29 2011, 06:34PM
SGTC here is the link to my schematic: Link2
The secondary is 500 turns of 28 gauge
and my primary is 23 turns of 14 gauge
my hv power supply is an 8kV 30mA NST
my capacitor bank is just a small leyden jar
my spark gap fires at about 1 mm
the length of the sparks fromthe ssecondary is about 2mm
HDF49
Sat Oct 29 2011, 06:49PM
HDF49 Registered Member #977 Joined: Thu Aug 30 2007, 06:57PM
put your coil's parameters into javatc and tune it, your primary should be below 15 turns so it looks like there'll be quite a bit of adjustment with the primary capacitor.
Electrikid221MnM
Sat Oct 29 2011, 07:08PM
javatc did not work so i think im gonna need some real help
Marko
Sun Oct 30 2011, 05:24PM
Hi sir,
Well the first step in increasing the spark length would be starting to use google extensively, and realizing pitfalls of your design such as your TC schematic being completely wrong and getting some basic idea on how it works.
I'm not within this flow anymore but sites like this used to be good places for starters: Link2
I guess your design would go something like this:
- Find a power supply: you already got over this one.
- Find out the right capacitor size for your power supply (google for it).
- Wind a secondary in accordance to your power input/expected spark length. Do it with the thinnest wire you practically can (for this coil size).
- Find out the resonant frequency of your secondary and build a primary in accordance to this. (Wire is ok for a small coil like this, no need to use tube)
- Build a spark gap by soldering some copper tube pieces onto a PCB, and using stacked paper sheets to carefully space them, and use a simple muffin fan to cool it. (don't build the complex TCBOR-style gap)
- Learn about NST protection and design a low pass filter for it (it can be as simple as 2 bottle caps and a stack of resistors).
Questions like this have probably been asked hundreds of times here over and over, and even though the search function of this site sucks you might have luck to run into some of them. In any case there's tons of work in front of you just in research!
Cheers,
Marko
M.A.D.
Mon Oct 31 2011, 03:18AM
M.A.D. Registered Member #4052 Joined: Thu Aug 11 2011, 04:43AM
yeah, I looked at your schematic and it has some major ploblems, I am suprised that you got any arcs from this. With this schematic no power is sent through the coil and I would suprised if you are not destroying you NST. there are a LOT of websites that give information on SGTC's. As already mentioned google "spark gap tesla coil' and you will find plenty of info.
Electrikid221MnM
Wed Nov 02 2011, 06:55PM
I've actually got the best sparks from that schematic, I'm just wondering if there are any tweaks I could makento the circuit.
Polonium210
Wed Nov 02 2011, 10:30PM
Polonium210 Registered Member #3450 Joined: Sun Nov 28 2010, 05:01AM
Electrikid221MnM wrote ...
The schematic you used was drawn by me before I had done any research on coiling. It was never meant for anyone to use and has now been taken down from my Flickr photos.
If you want better sparks I would use JavaTC to your advantage. Plug some numbers in and come up with a design from there.
Tetris
Thu Nov 03 2011, 10:51PM
sounds sort of like my own failcoil
what people told me: SG distance is important. cleanliness of windings are important--no crosses in secondary (too late in my case) primary should not look like a 2nd grader wound it (i'll fix this along with next case) and the caps are important too. my caps are also leyden jars. :P waiting on a shipment of real ones. not saying that the leyden jar isnt real.. but you get my drift. I don't have JavaTC, but I think you can torrent it. let me see if I can find torrent link.
Not a torrent. but here: Link2
I am not sure if the link causes direct download... but it works.
