  • Guests: 64
MOT Question
Kiwihvguy
Sat Oct 29 2011, 04:57AM Print
Kiwihvguy Registered Member #3395 Joined: Thu Nov 04 2010, 08:42AM
I was wondering what actually would happen to the output of a MOT (and the MOT itself) if you did either of these options:
1. Connect the high current tap in series with the HV winding,
or
2. Connect the the two high current and HV windings in parallel.
Apart from possibly providing a much higher current output (therefore bigger arcs) I would expect something to get fried very quickly.
For option 2, would phasing be necessary in order to prevent short-circuit on the windings?
What your thoughts?
Chip Fixes
Sat Oct 29 2011, 05:50AM
For 1 the cores would saturate very quickly. For number 2 you will, at the very least, trip a circuit breaker
Kiwihvguy
Sat Oct 29 2011, 06:49AM
Yeah, that's pretty much exactly what I thought. I wouldn't really care if one of my crappy MOTs saturated to death.
For option 1, would the arcs become huge due to the high current?
Sat Oct 29 2011, 09:16AM
What do you mean by "high current tap"? If you mean the filament winding and connected it in series with the secondary, the output voltage would be just a few volts higher (or lower depending on phasing). The output current would be almost the same (the impedance of the HV winding is dominant). If you connected the two windings in parallel, it would be just almost a perfect short circuit for the HV winding and the MOT would overheat quickly. The output voltage in this case would be a few Volts from the filament winding.
Kiwihvguy
Sat Oct 29 2011, 10:09AM
Yeah, I meant the filament tap. Right, I see no use for the filament tap to provide a higher current HV output.
My suspicions have been confirmed.
Ash Small
Sat Oct 29 2011, 11:13AM
I assume you're thinking about ways to superimpose one onto the other, as in HF TIG welder supplies.
I think you'd need a second transformer, with a 1:1 ratio, or whatever, and with windings able to take the current, but I'm still not sure if this would work.
Maybe someone else can comment?
(HF TIG welders use an air core transformer with 'loose' coupling, and one frequency much higher than the other. You'd be better off superimposing the output from a small SGTC circuit onto the 50Hz output from your MOT, I think)
Kiwihvguy
Sat Oct 29 2011, 11:21AM
I was only trying to see if I could get a much higher current output on the high voltage winding to get bigger arcs using a single MOT but no.
Ash Small
Józef C wrote ...
Have a look at this circuit:
1302453905 3414 FT112240 Hf
Kiwihvguy
Sun Oct 30 2011, 11:56PM
My goal wasn't to create a MIG welder kinda PSU. I was just checking things out with MOTs. Case closed for me.
GrantX
Tue Nov 01 2011, 01:50AM
Ash Small wrote ...
Imagine if you had a TC and a resonant MOT 4 pack superimposed together. 2 meter screaming death arcs anyone?
Although, I imagine it would be a horror to build.
