  • Guests: 37
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
optical fibre
Claude
Sat Oct 29 2011, 03:28AM Print
Claude Registered Member #3379 Joined: Mon Nov 01 2010, 06:34AM
Hi, I'm thinking of using FB128-ND (transmitter) and FB124-ND (reciever) for an interruptor and I am trying to find out what diameter optical cable fits these units. The specs sheet does not list this and I believe that the plastic cable comes in different thickness.
Does anyone know if this cable can be purchased from Digikey in cut lengths.
Thanks
Claude.
MrMatt
Sat Oct 29 2011, 03:36AM
MrMatt Registered Member #4156 Joined: Fri Oct 21 2011, 05:19PM
Going to use same style on mine, uses 1mm core fiber, 2,2 mm jacket I believe, FB140-1-ND is the PN for fiber by the meter
Herr Zapp
Sat Oct 29 2011, 06:22AM
Claude -
If you look at the Digikey catalog page (Link2 you'll see all the cable options, couplers, etc. for this series of optical modules.
Herr Zapp
Claude
Sat Oct 29 2011, 07:30AM
thanks to everyone who answered my question on fibre optic cables
Claude.
dude_500
Sat Oct 29 2011, 08:00AM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
I would suggest the FB123-ND since it has a TTL/CMOS output whereas the FB124-ND has open collector. Both would work, but the 123 is probably easier to use... unless you really like open collector outputs. Saves a resistor and schmitt gate if you go with a TTL output.
MrMatt
Thu Nov 03 2011, 04:25AM
i was just using the fb123-nd to test it, a word of caution, it has a up to 6us propagation delay, and on mine it was 1.5 on rising edges and 1.9 on falling, this may not be a issue for most, i wanted to use one for an external clock and this would be a big problem, especially the duty cycle getting ruined by delays. the fb120-nd is just a photo diode, but I am going to try it out
