  • Guests: 45
DRSSTC PRIMARY WAVEFORM
Claude
Fri Oct 28 2011, 11:16AM Print
Claude Registered Member #3379 Joined: Mon Nov 01 2010, 06:34AM
Hi, just finished my drsstc. runs great producing 36" arcs to a target.I decided to scope the primary waveform and noticed that it had a strange shape. It has the correct number of cycles according to the pulsewidth but it dips halfway through the on time.I have attached a scope shot. Sorry about the quality.
I don't know what could be going on here. I was hoping someone could help. I've seen pictures of other primary waveforms and they rise to peak current then continue evenly until shutdown.
Specs are:4.5"x12" secondary with 30awg wire 4"x13" spun torroid
Flat primary with 0.25" copper tubing tapped at 4.9 turns
coupling 0.179
halfbridge with voltage doubler 400v buss voltage
resonant frequency 175Khz
primary current 350 amps
Thanks
Claude.
1319800572 3379 FT0 Dsc02042 Copy
Uspring
Sun Oct 30 2011, 05:23PM
I posted a similar question recently. See the reply in
Gregory
Sun Oct 30 2011, 06:35PM
What is happening is that yours primary are tunned at the same frequency of the secondary. You need to low a bit the primary frequency
