  • Guests: 36
creating my own driver, sch attached
MrMatt
Fri Oct 28 2011, 12:43AM Print
MrMatt Registered Member #4156 Joined: Fri Oct 21 2011, 05:19PM
Ok I am modifying my driver circuit for my SSTC / DRSSTC. I am using a lab DC supply of 2.8kw at 62 volts. Therefore i am going to use a FET based driver. I have the provisional circuit attached, i still need to add some bypass caps and a few other bits.
I looked over Steve Ward's driver circuit and hope mine will function in a similar way. My circuit has on board oscillator (555 plus FF), DRSSTC and external clock options. Interrupter and over current are also implemented. I will be putting fiber receivers for the interrupter and external clock options.
Have a look and any advice is appreciated.
thanks
Matt
]tesladriver.zip[/file]
Luceš
Fri Oct 28 2011, 12:11PM
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
just letting you know, with 62 volts its not going to want to draw very much current, Most people put voltage doublers to get upwards of 200volts.
MrMatt
Fri Oct 28 2011, 06:04PM
in preliminary tests i was pulling almost 40 amps rms in CW with 60 volts on the bridge and a somewhat de-tuned primary circuit (about 1.6 ohms, inductive). I know i wont be pulling huge amps at this voltage, but i dont see why i cant get a couple hundred if i tune me LC primary to near zero ohms when running with an interrupter
MrMatt
Fri Oct 28 2011, 06:06PM
these are my coil parameters
J A V A T C version 12.5 - CONSOLIDATED OUTPUT
October-28-11 11:05:58 AM
Units = Inches
Ambient Temp = 68°F
Surrounding Inputs:
48 = Ground Plane Radius
60 = Wall Radius
80 = Ceiling Height
Secondary Coil Inputs:
Current Profile = G.PROFILE_LOADED
3 = Radius 1
3 = Radius 2
12 = Height 1
37.5 = Height 2
1020 = Turns
23 = Wire Awg
Primary Coil Inputs:
Round Primary Conductor
5 = Radius 1
8 = Radius 2
12 = Height 1
17 = Height 2
6 = Turns
0.25 = Wire Diameter
0 = Ribbon Width
0 = Ribbon Thickness
0.15 = Primary Cap (uF)
0 = Total Lead Length
0 = Lead Diameter
Top Load Inputs:
Toroid #1: minor=6, major=25, height=38, topload
Secondary Outputs:
148.33 kHz = Secondary Resonant Frequency
90 deg° = Angle of Secondary
25.5 inch = Length of Winding
40 inch = Turns Per Unit
0.00243 inch = Space Between Turns (edge to edge)
1602.2 ft = Length of Wire
4.25:1 = H/D Aspect Ratio
32.3486 Ohms = DC Resistance
30383 Ohms = Reactance at Resonance
2.47 lbs = Weight of Wire
32.6 mH = Les-Effective Series Inductance
34.352 mH = Lee-Equivalent Energy Inductance
33.535 mH = Ldc-Low Frequency Inductance
35.315 pF = Ces-Effective Shunt Capacitance
33.514 pF = Cee-Equivalent Energy Capacitance
52.966 pF = Cdc-Low Frequency Capacitance
7.55 mils = Skin Depth
29.52 pF = Topload Effective Capacitance
103.5821 Ohms = Effective AC Resistance
293 = Q
Primary Outputs:
114.2 kHz = Primary Resonant Frequency
23.01 % high = Percent Detuned
59 deg° = Angle of Primary
20.42 ft = Length of Wire
3.39 mOhms = DC Resistance
0.722 inch = Average spacing between turns (edge to edge)
1.864 inch = Proximity between coils
0 inch = Recommended minimum proximity between coils
12.948 µH = Ldc-Low Frequency Inductance
0.08892 µF = Cap size needed with Primary L (reference)
0 µH = Lead Length Inductance
141.678 µH = Lm-Mutual Inductance
0.215 k = Coupling Coefficient
0.135 k = Recommended Coupling Coefficient
4.65 = Number of half cycles for energy transfer at K
19.77 µs = Time for total energy transfer (ideal quench time)
Dr. ISOTOP
Fri Oct 28 2011, 09:06PM
MrMatt wrote ...
Even if it pulls thousands of watts, it'll still have derpy sparks; SSTCs want voltage, not raw power.
MrMatt
Fri Oct 28 2011, 09:48PM
How much of a restriction does low drive put on arc length?. When running CW right now i am getting about a 14" arc. I would imagine if I ran an interrupter at 10% or so and jacked up the current the arcs would lengthen quite a bit. Never the less this circuit could be used to drive GDT just as easy as the primary in the future. Another idea that pops into my head is a transformer, but that may be a headache to build one that would not survive such high peak powers
Luceš
Fri Oct 28 2011, 10:27PM
why don't you post some pics and schematics
MrMatt
Fri Oct 28 2011, 10:46PM
schematic preliminary is in first post, very similar to what i am using right now/ was using I did something dumb and blew the driver chip. i was just adding interrupter, better on board clock source, and drsstc options as well as over current protection.
would to nice to know if i am on the right track with self resonant driver in my circuit as attached above
pic attached of coil, and yes i did fry those alligator leads, was doing some low power tuning and forgot to take them off. oops
1319841954 4156 FT127101 Coilpic1
