  • Guests: 21
Ben7 (29)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
Weird flyback driver
Platinum
Wed Oct 26 2011, 06:54PM Print
I've had alot of success with CFL ballast flyback drivers, but I've wanted to get more form them, so is there anyway I could use CFL ballasts in series or parallel for more flyback arc?
Inducktion
Wed Oct 26 2011, 07:42PM
I wouldn't see why not, as long as they're identical.
Platinum
Wed Oct 26 2011, 08:09PM
They are 240V, And not identical :(
Xray
Fri Oct 28 2011, 08:10PM
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
Platinum wrote ...
My educated "guess" is NO. The problem is that the waveforms from the two ballasts would not be in synch, and so they would be fighting each other when they happen to go out of phase. You would probably end up with two blown ballasts. mad
Pieznice29
Fri Oct 28 2011, 11:35PM
Pieznice29 Registered Member #3918 Joined: Sun May 29 2011, 08:42PM
Just like Xray said, unless you found a way to synchronise them, you would probably just end up with a puddle of molten CFL ballast. Keeping them in sync is probably possible and might work, but several times more difficult than just building say a ZVS driver.
You might even be able to get quite a few of the components for a ZVS driver out of CFL ballasts (Diodes, zeners, resistors, inductors).
Platinum
Sat Oct 29 2011, 02:12PM
OK thanks anyway guys, I'm going to buy a halogen transformer, They work good as long as they are not really cheap and well built, I've had very good success with them.
I'm bored atm is there anything I fun I can do with a very low voltage flyback, it's about 7K volts.
Also I had a candle near the negative HV output of the flyback and it was sucking the flame in near it, and when I put the positive output near it would push it away, mainly because it was spraying, maybe the negative is the positive effect of the spraying positive.
Platinum
Sat Oct 29 2011, 09:50PM
I have 2 400 330UF caps, is there anything I can do with them?
Xray
Sun Oct 30 2011, 06:57PM
Platinum wrote ...
That's like asking, "I have a container of bolts. Is there anything I can do with them?" Of course there are things you can do with them! You need to be more specific, like what do you want to do with them?
