  • Guests: 45
Faraday Cage
LD LANGER
Wed Oct 26 2011, 02:17PM Print
LD LANGER Registered Member #3824 Joined: Sun Apr 10 2011, 08:29PM
Hello,
I have looked throughout the forum, but unfortunately I cannot find the information I require at this time.
I am looking for some help regarding Faraday cages for my DC resonant tesla coil.
1. Will a faraday cage solidly grounded to my dedicated RF ground reduce the length of my arcs?
2. At 250 kHz, does a wire spacing of 5" sound viable in reducing field strength outside the cage?
Any help would be much appreciated.
Thanks,
Daniel
M.A.D.
Thu Oct 27 2011, 03:34AM
M.A.D. Registered Member #4052 Joined: Thu Aug 11 2011, 04:43AM
I did some small scale tests on faraday cages a while ago, and as far as I could tell, when the cage completely enclosed the coil and was connected to both the coils RF ground and mains ground, it completely eliminated interference outside of the cage.
However these tests may not have been conclusive because I do not have proper measuring equipment (I was using a fluorescent tube and an AM radio) and also the added capitance horrifically detuned my coil and I was unable to get it even close to resonant so my spark length was maybe a 1/5 of normal.
I think and I maybe wrong, but if you can retune your coil to adjust for the new, lower secondary resonance the spark length might return to normal.
I am planning on building a Faraday cage for the SSTC that I am working on, so I will let you know what I find out, however that is not going to be anytime soon.
