  • Guests: 33
Building my first ZVS driver
lvanst
Sun Oct 23 2011, 04:59AM Print
lvanst Registered Member #4154 Joined: Fri Oct 21 2011, 05:22AM
Vladimiro-Mazzilli's circuit seems to be the holy-grail, though I suspect there are better options than the original IRFP250s.
Does anyone offer a quality kit?
Is there a favorite flyback I should order? (not from disinformation unlimited!)
This humble newb will most graciously appreciate any advice available... wink
lvanst
Sun Oct 23 2011, 05:14AM
I'm assuming this is no longer an option: Link2
lvanst
Sun Oct 23 2011, 07:22AM
This is helpful: Link2
I guess IRFP250s are not as outdated as I thought...
Anyone making circuit boards?
Sun Oct 23 2011, 09:44AM
Advice: if your going to post here please, READ THE RULES
(Use the edit button and dont double post let alone triple post)
Ocean Waves
Fri Nov 04 2011, 10:46PM
Ocean Waves Registered Member #4181 Joined: Thu Nov 03 2011, 02:39PM
now would be a good time for you to learn to make pcb's your self or just mock it up on ring board, for such a simple circuit ring boarb bac be just as fast as a pre made PCB, I would only want a pcb if the circuit was large or i was going to make a lot of them, so if your going to make a lot of them tray the toner transfer methiod using photopaper and a photo copier, works well if you are careful, touch up can be made wiht a sharpie.........you already posted the link with artwork, i belive that member is encouraging people to make there own boards :)................
