  • Guests: 34
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
HFSSTC question
hsieh
Sat Oct 22 2011, 11:59AM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I am considering to build this coil Link2 because I like it's simplicity.But if I want it to run at lower frequency(600KHz),how should I modify it?or is this circuit "self tuned" and don't require tuning?and can I use a different MOSFET?
Tetris
Sun Oct 23 2011, 12:40AM
When you finish it, touch the arcs. You won't feel a thing! XD if you use a strip of metal that is. The arcs will still be hot.
Turkey9
Sun Oct 23 2011, 01:23AM
This circuit will only run at the resonant frequency of the coil. You should be able to get it to run at a lower frequency by increasing the number of turns on the secondary. The secondary he uses is pretty small so that is most likely the reason it runs at such a high frequency.
hsieh
Sun Oct 23 2011, 02:06AM
Turkey9 wrote ...
So I can use a secondary that has a lower resonant frequency without changing anything in the circuit?
