  • Guests: 48
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
MegaVolt Vacuum Tube Tesla Coil
zilipoper
Fri Oct 21 2011, 12:51AM Print
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
Greetings to all!! amazed
sorry for my bad english =))
My second Nano VTTC GMI-46
The resonant frequency of 160kHz
maximum spark length 30-35 inches
1319157861 4152 FT0 Sam 1453
1319157873 4152 FT0 Sam 1479
1319158255 4152 FT0 Y 2035db85
Fri Oct 21 2011, 01:42PM
Beautiful hot arcs zilipoper. Good tube. Well done!
Marko
Fri Oct 21 2011, 02:49PM
Huh, if that is nano, I must wonder what would be a giga or tera VTTC for you then? suprised
How do you control the attitude of the spark in second video (from very branched to relatively straight-flailing-whippy)?
Marko
zilipoper
Fri Oct 21 2011, 04:07PM
here 40 inches streamer! amazed suprised
328fbf33ac4b
zilipoper
Mon Oct 24 2011, 08:30PM
What do you think of this at the expense of power?
1319488219 4152 FT126590 56
Mon Oct 24 2011, 09:16PM
If you want to use that circuit for a VTTC, you will need a filament transformer with pri-sec insulation rated at least for 3 kV, this means you'll most likely need to wind a special transformer for your application.
teravolt
Tue Oct 25 2011, 03:10AM
nice coil. Do you plan to use a coil with a higher resonance around 400khz? How much power are you sucking from the wall?
I like the way the spark dances I wonder if a higher frequency would make it more sword like. you might reach the sealing then
In the "nano VTTC" it looks like there are two types of modulation one that branches and one that makes the spark turn into a columb or combine. What exactly are you doing to make that happen. I am thinking is it pausible to make a VTTC that has a some what directible arc and i have been told that it is frequency 350 khz to 500 is the magic frequency for sword sparks but also modulatin to the power is necisary to grow the spark and thats how Phillip Slawinski gets the length in your last thread for the gmi-38.
Tetris
Tue Oct 25 2011, 08:06PM
Damn, that is the coolest VTTC I've ever seen! :O love how you solarized the video beginning to set the mood. Beautiful arcs!!!!!!!!
zilipoper
Sun Oct 30 2011, 07:01PM
update
55inches;-)
1320000997 4152 FT126590 1
1320001069 4152 FT126590 2
1320001089 4152 FT126590 3
1320001108 4152 FT126590 4
1320001131 4152 FT126590 5
1320001163 4152 FT126590 6
1320001163 4152 FT126590 7
1320001203 4152 FT126590 10
1320001203 4152 FT126590 9
wink
Sun Oct 30 2011, 08:13PM
Wow, beautiful!! The first streamers emerging from the toroid itself on a VTTC setup. Great!
