  • Guests: 42
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Big Pulsed Vacuum Tube Tesla Coil GMI-38
zilipoper
Fri Oct 21 2011, 12:12AM Print
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
Greetings to all!! amazed
sorry for my bad english =))
I present to you the impulse mini VTTC
The resonant frequency of 600kHz
pulse energy 300Joule
voltage 6kV
capacitor 17µF 7kV:-D
tube--GMI-38 amazed
1319154927 4152 FT0 1
1319155041 4152 FT0 2
1319155328 4152 FT0 3
[link][img]https://4hv.org/e107_files/public
1319155367 4152 FT0 5
1319155422 4152 FT0 Sam 0827 001 0012
YouTube
RSG+ VTTC
amazed
upgrade coil
capacitor --7000Joule
tube--GMI-32
Coming Soon!amazed
511b3ab43292
3b7b6972e5ac
Dr Hankenstein
Fri Oct 21 2011, 03:29AM
Dr Hankenstein Registered Member #1642 Joined: Sun Aug 17 2008, 11:36PM
That's totally insane, dude!
teravolt
Fri Oct 21 2011, 04:53AM
very cool zilipoper I see why you are interested in my thread to. the tube in my avatar is a GU-39b-1
what made you use a pulse tube? it seems logical to me. how do you make it work because there must be some sort of oscillations going on. I looked at the data sheets and it doesn't seem like it will handle a lot of power but it is as big around as my gu39b. would you like to give us a basic idea of how you are using it, maybe a schematic
zilipoper
Fri Oct 21 2011, 01:05PM
this scheme:-D
By IRf840 can connect the audio modulation:-p
1319201583 4152 FT126587 Sam 1859
all pulse tube big anode voltage
30-40kv.
big anode current 10-100А! amazed
output power GMI-32B in pulsed 3 megawatt!amazed
GU-39b-1 monster tube:-D
low power mode VTTC
Marko
Fri Oct 21 2011, 02:39PM
Congratulations sir, this is fairly epic. So VTTC's can indeed be ran in "QCW" mode after all! Also at much crazier energies than igbt coils do, at cost of lower break rate...
Now you just need to figure out how to control the rampup of primary current (perhaps an old-fashioned pulse forming network?) so you can grow your swords to epic lengths.
Cheers,
Marko
Phillip Slawinski
Fri Oct 21 2011, 08:17PM
Phillip Slawinski Registered Member #1732 Joined: Thu Oct 02 2008, 02:34PM
Yes a Valve coil can be run almost exactly like a QCWDRSSTC. Been there, done that, and I have the photos/videos to prove it. cheesey
Meet the SSVC (Solid State Valve Coil):
zilipoper
Fri Oct 21 2011, 09:00PM
Hi Phillip
I saw your infernal SSVC cheesey
can not imagine how tubes do not shoots 20kv???:-O:-O suprised
Sun Oct 23 2011, 01:50PM
RSGVTTC, that sounds scary, thumbs up for mixing the topologies :)
teravolt
Mon Oct 24 2011, 07:31PM
Phillip great work, do you think that a SSVC is a sapirior topoligy over a QCWDRSSTC setup? it would seem that it is from the size if your sword sparks. The fact that the tube can handle a higher bandwidth would help verses slow fets for the 350 to 500khz that is needed. Has the tube ever flashed? The fact that you have high 20kv for only a moment may keep it from flashing what do you think
Marko
Mon Nov 07 2011, 12:51PM
Hi zillipoper,
Any news on the monstrous 7kJ coil? Are you going to use this existing secondary or are winding a new one? Perhaps with some QCW-like current control the old one could work well too without exploding to pieces? (something simple like sensing secondary base current and feeding this to a comparator which turns the tube on/off while comparing this to a ramping reference?
Marko
