  • Guests: 49
Remote Electronic Switch.
The_Happy_Duck
Thu Oct 20 2011, 08:56PM Print
The_Happy_Duck Registered Member #4089 Joined: Fri Sept 09 2011, 04:40PM
Hello,
This may be the wrong forum to post in but it is the most convenient. I was just quickly wondering where I could find a switch for an electronic circuit which operates remotely (wirelessly), say a button. An example would be that you press the switch and it pushes two contacts together which completes the circuit and electricity is allowed to pass through, possibly turning an electronical device on if linked correctly.
Thanks,
GrantX
Fri Oct 21 2011, 08:55AM
Hmm, maybe a relay that's coil is energized by an IR or wi-fi switch of some kind?
I'm sure there would be a solution available somewhere, but I've honestly never looked for anything like that.
AndrewM
Fri Oct 21 2011, 02:35PM
I've used things like this Link2 before, they come with a little remote like for a car door. I think I can see everyones favorite chinese ASK receiver sticking up on that board.
doctor electrons
Sun Oct 23 2011, 01:19PM
Everything you need is in a used garage door opener ;)
haxor5354
Mon Oct 24 2011, 12:19AM
u mean a relay switch controlled by an IR or RF controller?
