  • Guests: 45
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
Eimac 4-250A
christensenda
Thu Oct 20 2011, 06:11PM Print
christensenda Registered Member #3062 Joined: Wed Aug 04 2010, 02:07AM
I was browsing the internet and stumbled across several VTTCs run by 4-250A tubes and was wondering about the output spark characteristic. I noticed that even with a Level shifter several coilers still only received several inches of arc, but yet it appeared as though almost to be a flame. Granted all the resonant frequencies seem a little higher than normal but I found this curious and wondered if someone could shine some light on this, and why the performance seems a little diminished as to what one might expect.
Also, if this would be a suitable tube for an audio modulated VTTC?
Thu Oct 20 2011, 07:29PM
I think you might expect some 10-12" sparks from a well tuned coil with this tube. The higher the frequency, the shorter the sparks are for the same power but they are hotter and brighter.
U4R1A
Thu Oct 20 2011, 09:35PM
U4R1A Registered Member #3505 Joined: Sun Dec 12 2010, 06:03AM
I get ~10" from my 4-125a VTTC and I haven't poured much time into tuning it since I got the mica tank caps.
