  • Guests: 58
Slightly dissimilar NSTs - Parallel??
GrantX
Thu Oct 20 2011, 08:11AM Print
I just got given an NST by a nice signmaker today, and it's very close in specs to my big NST, so I'm wondering if they can be paralleled?
One is 7.5-0-7.5 kV and the other is 6-0-6 kV. Both are 60mA.
What's going to happen with the 1.5 kV difference on each output? Will this cause any destructive currents in either transformer?
I'm hoping it'll just give me 12 kV 120mA across the outputs, but I'm worried that bad things will happen....
Either way, I still can't believe he gave it to me for free :D
Thu Oct 20 2011, 01:14PM
What you want is not parrallel your thinking of series parrallel only ups the current your trying to up both the current and the voltage
Marko
Thu Oct 20 2011, 01:37PM
The proper way would be to use a buck transformer on primary of your first NST. If your line is 240V then you'd need a 48V buck transformer, with current equal ti input current of your nst.
You could also just use a variac for start.
Marko
GrantX
Fri Oct 21 2011, 08:46AM
Tom Williamson wrote ...
The NST's provide 12kV and 15kV across their outputs respectively, and both are 60 mA. I'm looking for 120 mA at 12-15 kV. So I want parallel, since I want more current without any change in voltage.
@ Marko: A buck transformer sounds like the best idea. That will bring the big NST down to 12 kV, correct?
I only have a 500VA variac, but I changed the fuse to a 5A one, so technically it can run one NST, but I don't want to overload it.
M.A.D.
Sat Oct 22 2011, 08:05AM
M.A.D. Registered Member #4052 Joined: Thu Aug 11 2011, 04:43AM
If you put them in parallel you would get 12KV at 120mA. However the lower voltage one would suffer. I read somewhere that even though you would only get 12KV the insulation on both transformers still has to deal with 15KV, because the difference in voltage is shorted into the lower voltage transformer.
I think that lowering the input voltage on the 15KV transformer probably is your best option. If you are worried about you variac you could probably just make your own step down transformer out of a MOT or something similar.
buxtronix
Sat Oct 22 2011, 08:37AM
buxtronix Registered Member #4078 Joined: Tue Aug 30 2011, 12:53PM
I think it depends on how you're using them. Remember that an NST's output voltage will drop a fair bit under load, so if you are using them in a way that loads them from the start, you can probably get away with it.
I have a pair in parallel that arent exactly matched (My HV probe shows a KV or so difference), but they dont have a problem at all in parallel. The extra stresses induced are no more than 10% either side of their ratings, which should be survivable.
