  • Guests: 34
01/13 si2030 (62)
Mercury Arc Rectifier
Download
Sat Oct 15 2011, 06:04AM Print
Download Registered Member #561 Joined: Sat Mar 03 2007, 02:46AM
So I recently contacted Adelaide Metro, the public transport department that runs all the trams in my city. When I asked them about possibly getting an old mercury arc rectifier they responded telling me they stopped using them years ago, and that they didn't have any left. So does anyone know if any state in Australia might still use them? Maybe they only got rid of them a couple years ago and might have some stored away somewhere? I was hoping to get one to add to my glassware collection I'm beginning to build up
Adam Munich
Sat Oct 15 2011, 08:41PM
You do realize that these fragile bulbs are 3' across, filled with a vacuum and require several strong men to carry right? tongue
Sun Oct 16 2011, 11:32AM
You forgot the main problem - they contain loads of mercury.
I'm also searching for one.
Avalanche
Sun Oct 16 2011, 12:08PM
I've seen pictures of abandoned cinemas which have been urbex'ed, and most of those contain smaller mercury arc rectifiers for the old lighting systems. Might be worth trying to find some old cinemas/theatres and contacting the owners?
radiotech
Mon Oct 17 2011, 01:38PM
Some were called Hewittic rectifiers. My mate and myself almost blew one up in
a plant where it was used to run a 'roll grinding machine'. We made a switching
blunder during tests that caused the main contactor to close into a stopped motor.
We ended up replacing six large fuses and never revealed what happened.
The bulb for that machine was shipped in a wooden case and suspended on springs.
There are little ones, too. They were used in charging panels, and needed a rocker to
tilt them to start. The maintenance department once mounted one of those in a plexiglass
case for display. We electricians called those mercury rectifier systems a 'Buck Rodgers'.
M.A.D.
Wed Oct 19 2011, 03:31AM
M.A.D. Registered Member #4052 Joined: Thu Aug 11 2011, 04:43AM
There is just something cool about something that boils mercury in a vacuum to create DC.
Download
Fri Oct 21 2011, 05:48AM
I think I'll try contacting some old Cinemas, there is plenty around here
radiotech
Sat Oct 22 2011, 10:15PM
Since you had asked, I found this in the files here.
1319321705 2463 FT126204 Hewletticbook
