  • Guests: 43
Sulaiman (71)
teslarevolution (29)
AromaZ (69)
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
wanted: HV cap and wire
lokeycmos
Wed Oct 12 2011, 02:38AM Print
lokeycmos Registered Member #2553 Joined: Fri Dec 18 2009, 01:36PM
Please let me know if someone has 30kv+ caps for cheap. also looking for a source of 24g magnet wire. 1 need about 1000'. i will buy if you have a better deal than online vendors.
Adam Munich
Wed Oct 12 2011, 04:18AM
VTTC?
In that case you'd want 'doorknob caps'.
lokeycmos
Wed Oct 12 2011, 04:17PM
SGTC. whats a doorknop cap? is it better to have one cap with an over voltage rating or MMC? i was thinking about cutting apart monitor flybacks(they commonly have a HV cap inside) and using that cap. they are 30kv+ what do you think?
Forty
Wed Oct 12 2011, 10:21PM
Flybacks are very hard to disassemble successfully.
Dr. ISOTOP
Thu Oct 13 2011, 01:31AM
lokeycmos wrote ...
You should read more about SGTCs...they require a very robust tank cap.
It is recommended to use either a small Maxwell 37* series cap or a MMC of CDE942's.
