  • Guests: 40
Testing pole pigs and other big transformers
buxtronix
Tue Oct 11 2011, 10:53PM Print
buxtronix Registered Member #4078 Joined: Tue Aug 30 2011, 12:53PM
I've managed to convince a large metal scrapyard to let me dig around their piles of transformers for
whatever I want (they are the "official" recycler for the local utility). Excellent news...but...
I think most of what's there will be faulty in some way, so quite useless. However I'm hoping that
some of the gear comes from decommissioned installations where it's just considered obsolete, not broken.
So i'm looking at suggestions as to how I can do basic tests in the yard before I haul something heavy
home for proper testing.
Aside from a continuity check with a meter, what else can I do?
I've had the idea of making a small 12v powered 50Hz h-bridge driver to feed into the low voltage side, and
measure the secondary. Are there other or easier ways to test onsite?
Luceš
Tue Oct 11 2011, 11:26PM
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
you could check the resistance on the hv primary, although this would be quite a stab in the dark, If you do find a decomissioned transformer, odds are its filled with pcb. neutral witch is fine... until you have to dispose of the transformer!
Cain
Thu Oct 13 2011, 01:28AM
Cain Registered Member #624 Joined: Tue Apr 03 2007, 07:50AM
a HV probe, a battery and a small inverter?
Dr. ISOTOP
Thu Oct 13 2011, 01:30AM
Pigs are incredibly robust...if you find a pig, chances are its just been decommissioned, not dead.
buxtronix
Thu Oct 13 2011, 01:59AM
Cain wrote ...
Actually now that you reminded me, I do have a small inverter somewhere. And an HV probe. That after some basic continuity/resistance checking should solve my my problem!
Luceš
Thu Oct 13 2011, 02:42AM
bwang wrote ...
Except for they like to explode when over loaded past 200% amazed I've seen 1 exlpode in my life time, it was at montivideo MN at a steam show, too much power draw... BOOM! smile
teravolt
Thu Oct 13 2011, 01:37PM
make shure the high side of the transformer is highpoted and will hold off the voltage. also make shure the turns ratio is still corect.
