  • Guests: 28
Tube plate and filament supply turn on sequence
Tue Oct 11 2011, 08:33PM Print
Hello, is it ok for the tube when the plate and filament windings are on the same transformer, so they get turned on at the same time? I know this isn't good with indirectly heated tubes, but does it matter with directly heated ones?
Luceš
Tue Oct 11 2011, 11:22PM
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
I've have wondered this before, I have seen a video of a guy that has made a tube amp with a gu-81m, he turned the B+ on before the filament, I can't imagine that it would be very good for things though.
Steve Maurer
Fri Oct 14 2011, 02:08AM
Steve Maurer Registered Member #133 Joined: Fri Feb 10 2006, 10:27PM
Good design practice is to always warm up the filament to its full operating temperature before applying plate voltage in order to prevent cathode stripping of the filament.
In addition, ramping up the filament voltage gradually will greatly extend the life of the tube. Suddenly applying full filament voltage to the filament stresses the filament due to high inrush currents when the filament is cold. Ramping the filament voltage over a minute or two will help extend the filament life. High power broadcast transmitters utilizing 20 kW tubes typically ramp up the filament voltage over a period of 5 to 10 minutes.
A good article to read concerning extending the life of power vacuum tubes may be found here:
Techniques to Extend the Service Life of High Power Vacuum Tubes
Luceš
Fri Oct 14 2011, 12:19PM
I am a soft start fanatic wink I soft start all my big tubes, most of them have a very short life anyway, WHY SHORTEN IT MORE angry
