  • Guests: 58
FAN7382 and FAN7392 problems
Inducktion
Mon Oct 10 2011, 12:13AM Print
Hello all, I've got several of the aforementioned IC's above, and ever since I've gotten them, I've had nothing but problems with them.
My issue? The High side never seems to want to work.
Basically, I've followed EXACTLY what the datasheet implies, using 1 uF as the bootstrap cap, a UF4007 diode as the bootstrap diode, and nothing as a bootstrap resistor (since apparently that slows things down, making more heat)
I've also used a 1 uF cap as the one going from Vcc to COM.
And, the SD input on the FAN7392 I usually put to ground.
And every time, it seems it just, fails to work properly! No signal, or a crap signal at that, and not even at the correct voltage for turning on the mosfet!
What's going on here.
Mon Oct 10 2011, 12:19AM
Have you tried the mods i suggested?
Lets start with the 7382 since its a wee bit simpler, then we'll move up to the other one, go get a temp or bread board.
