  • Guests: 68
what would cause a rf choke to fail on vttc?
Luceš
Wed Oct 05 2011, 01:47AM Print
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
this is my gu-81m vttc I was getting about 8 inch sparks (watch the video) I was using 8 soviet voltage doubler caps in series for a tank cap, some one at ham radio club said that was lower my Q factor (so I wasn't getting very big sparks), and that I should switch to ceramic door knob caps to make it ring longer. so I did, I put it on and got no out put, but at least it was oscillating, it lit up a light bulb at about 2 inches away, I thought... well its probably just out of tune mistrust I TRIED EVERY SINGLE TAP with the same results, after awhile I started to notice smoke coming from near the tube, so I shut every thing off. my RF choke was melted to waszu!!! Was it just a fluke that it failed with the new cap, or is it something else wrong associated with putting on the new cap.
Video of it run if before new cap here: Link2
thanks in advance
1317779269 4108 FT0 Img 0014
1317779269 4108 FT0 Img 0017
1317779269 4108 FT0 Img 0020
1317779269 4108 FT0 Img 0021
1317779269 4108 FT0 Img 0019
astralhighway
Wed Oct 05 2011, 11:59AM
astralhighway Registered Member #4107 Joined: Sun Sept 25 2011, 07:30PM
Hmm, that looks like a wirewound ceramic resistor. The resistor has unwanted inductance because it's wirewound. This will hamper the design of your circuit. I can see that the insulation on your turns heated up somewhat but your resistor also heated up a lot - the one probably caused the other. Your resistor looks completely blackened there. Can you post a closer-up photo - just as you have there but showing any damage to the resistor?
Luceš
Wed Oct 05 2011, 12:06PM
I'll try to post better pics, it will have to be this afternoon after school, I hope I can get a good enough pic cuz it's taken on my phone cheesey
And yes it's a 10 ohm wire wound resister.
Wed Oct 05 2011, 12:33PM
The capacitor was probably not intended for RF operation. If you use a ceramic cap, you must use one intended for the job. Such as Link2 or Link2 , preferrably with the kVAR rating marked on it.
Luceš
Wed Oct 05 2011, 08:43PM
!grr ahwell. would anyone be will to sell me (or trade for the old one) the correct capacitor?
btw here is the ebay listing in witch I bought it from Link2
astralhighway
Thu Oct 06 2011, 09:02AM
Very surprised to see that component fail - it's voltage rating is more than adequate and this is a rugged component totally fit for this application. What was the value of the capacitor before you fitted this one? You've got just a 1.3 nf cap there now. How many turns on your primary/ secondary? The circuit may wildly untuned.... just a hunch. That would explain a higher current through your valve/electron tube. Was the anode orange or red when your chokes failed? Lighting up a bulb just two inches away suggests feeble oscillation, maybe just a harmonic frequency.
Luceš
Thu Oct 06 2011, 12:00PM
I never had it on long enough to see if it got orange, before the new cap the anode would get orange with it running for 2 minutes. I know the primary wire is too thin, I'm building a new cabinet,and I will make a new primary with thicker wire,that should raise the q and drop the current going through the Valve.
Thu Oct 06 2011, 04:58PM
astralhighway: Most ceramic capacitors are not suitable for rf operation. I have a similar one with a green case which I tried in a TC. I also tried a red disk ceramic capacitor. Both caps resulted in very little sparks and they quickly heated up.
Capacitors suitable in a TC duty must be special ceramic caps, usually intended for tube transmitters or induction heaters. Sometimes a "non-specialized" cap will work, but most times it will contain just a standard dielectric which is very lossy.
Luceš
Thu Oct 06 2011, 08:42PM
were will I get a decent cap?
Fri Oct 07 2011, 08:29AM
search on ebay, try "russian doorknob", "russian capacitor", "plate capacitor", "rf ceramic" etc...
After you have seen a few caps, you can guess if the cap is suitable or not.
