  • Guests: 69
My newest handheld coil :)
Staci
Mon Oct 03 2011, 04:42AM Print
Staci Registered Member #1741 Joined: Sat Oct 04 2008, 02:45AM
My newest handheld coil. Runs on 18V cordless tool battery, weighs about 7 kilos, and fires about 20" to ground, 14" or so fiery discharge otherwise. I run at about 200W because any more and it hurts a lot due arc backs. Soon I add music modulation when I get new LCDs in.
1317616871 1741 FT0 Img 4273
1317616889 1741 FT0 Img 4268
1317616917 1741 FT0 Img 4262
1317616917 1741 FT0 Img 4260
1317616946 1741 FT0 Img 4274
Dr. ISOTOP
Mon Oct 03 2011, 04:53AM
Does it feed the bridge directly with 18V, or are you boosting it first?
Staci
Mon Oct 03 2011, 05:00AM
Is using a 3 phase BLDC motor as HVDC generator. The DC link runs about 240V with a fresh battery. Since it's a steampunk themed piece I decided not to go with a front end converter but rather a spinning gizmo instead. The circular saw also has the advantage of being an extremely rugged ABS chassis with nice ergonomics.
Mon Oct 03 2011, 05:26AM
Great work Staci, creative and it works, nice.
The motor/generator bit is inspired!
Completely mad .. I love it.
I believe that there's a danger hazard if you arc to mains as the arc may conduct mains to you, so take care.
Staci
Mon Oct 03 2011, 01:12PM
Thank you. I had often wondered about arcing to the mains knowing that the plasma is a reasonably good conductor. I recall a certain style of handheld tesla coil for medical use was notorious for just that but my knowledge of such is purely anecdotal.
At any rate, I'd certainly wish to avoid electrocution. Running entirely on batteries in a triple insulated chassis is nice especially nice for that reason. All I need to bring my freakshow on the road is a grounding cable and assortment of grounding fixtures.
johncohn
Tue Oct 04 2011, 04:04PM
johncohn Registered Member #1848 Joined: Sat Dec 06 2008, 03:24AM
Staci.. awesome design.. I want to build one !.. Can you resend me your contact info ? Thanks !
I wonder ... Could you make two oppositely phased ones and run them as a tandem ?
-jc
Moderator: Do not double post please, use the edit button.
astralhighway
Tue Oct 04 2011, 05:05PM
astralhighway Registered Member #4107 Joined: Sun Sept 25 2011, 07:30PM
Awesome. Really brilliant piece of engineering, thank you for sharing it!
