  • Guests: 33
Solenoid and Transformer Winding Jig.
Fri Sept 30 2011, 05:45AM Print
My new coil winder for Solenoids and transformers.
Better description will be available after i sleep.
1317361553 2431 FT0 Jig
The whole thing, spool of mag wire, hand crank, and all-thread that carries the winding bobbin. (solenoid bobbin seen here)
1317362569 2431 FT1630 Materials
1317362569 2431 FT1630 Partsmic
1317362569 2431 FT1630 Pieces
1317362268 2431 FT1630 Assembly1
1317362268 2431 FT1630 Assembly2
1317362268 2431 FT1630 Assembly3
1317362268 2431 FT1630 Assembly4
1317362360 2431 FT1630 Final
1317362360 2431 FT1630 Hand
Finished solenoid winding bobbin.
jpsmith123
Fri Sept 30 2011, 09:34PM
What kind of plastic is that? Teflon?
Is the idea to wind a coil on the form shown and then slide it off the plastic and eventually onto something else?
Fri Sept 30 2011, 09:38PM
jpsmith123 wrote ...
White Pvc sheet 3mm thick, not quite solid, but not foamed either.
yes, ill use Radhoos method for solenoids and transformer coils. mag-wire woud around wet epoxy, with no bubbles (i hope). But no vacuum needed either. Coil is 4 mm thick which is the max that radoo suggested.
EDIT: ill use castin' craft mold release to help ease the coils out.
jpsmith123
Fri Sept 30 2011, 10:53PM
What size wire will you be using?
Fri Sept 30 2011, 10:55PM
35 Awg.
Turkey9
Sat Oct 01 2011, 01:43AM
What's the application for the coils? The shape would suggest either a strange geometry on the core or some sort of brush less motor/generator.
Sat Oct 01 2011, 02:29AM
It just pulls up a zip drive for a flying robot (IARC 6). An obround Laminated steelcore section will go through the center.
Killa-X
Sat Oct 01 2011, 04:43PM
Patrick wrote ...
35 Awg.
Darn, I guessed 34 by the spool (Very similar to mine) Is the spool just riding on that copper tube? I understand 35awg is rather thin so you dont want to give it too much tension, and any sudden jolts would snap it.
Otherwise yeah, whatever works for you to wind your transformres =)
Sat Oct 01 2011, 04:59PM
Killa-X wrote ...
Patrick wrote ...
35 Awg.
I got the 35 Awg dumpster diving in 1999 ! it looks like about 2000 yards of wire, said "heavy insulated" and "35Awg "which menas double layers of the insulant. And yes i have that huge spool on two end bearings so the thin wire doesnt stretch and craze, i got some mods to make but it should roll real easy. it's 0.0055 inches in diameter.
