  • Guests: 119
Soldering Iron Detonation
Michael W.
Tue Jul 04 2006, 06:58PM Print
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
The other night I was sitting down for a hour of soldering, plugging in my iron, letting it heat up and then picked it up. As I lowered it towards the resistors I was going to tin...BANG. Followed by sparks, smoke and an eerie burning smell. As I look down I saw this.... (see picture) a large hole blown in the side. What a suprise, its a radio shack product. When questioned on it they said "oh well, too bad, we don't care" Now thats poor service....
1152039513 50 FT0 Ironexplosion
Marko
Tue Jul 04 2006, 07:13PM
Maybe they should include explosion hazard icon on newly produced irons ill
Ww3big
PS. my 666th post..
*big asteroid misses earth this time*
robert
Tue Jul 04 2006, 07:22PM
robert Registered Member #188 Joined: Thu Feb 16 2006, 05:18PM
Nice, yours blew up too?
I had a cheap 100w one blow up a few months ago, element shorted because the cheap isolation failed and the thin lead wires were mostly vaporized, the thin plastic grip cracked and the "barrel" deformed.
Blew the 16A fuse too and the bright flash made me see a orange spot for 2 hours later.
The soldering iron had less then 5 total hours, mostly running at 180v or even less from a variable transformer.
Marko
Tue Jul 04 2006, 07:41PM
Nope, I have an weller iron powered from lov-voltage station so it can't blow up. :p
Really interesting how it blew hole in solid metal. This could really be bad if pointed towards your hand, bonus you can also fry yourself badly dropping the iron after that ill
Tue Jul 04 2006, 10:40PM
Even the cheapest weller station will last at least 30 times longer (if not more) than those crappy radioshack irons. So even if the WLC100 is $40-50, its better than buying lots of the RS irons that only last for a few hours anyway. Save yourself some grief, and at the same time make better solder joints and buy a real station. Im still using the original tip, and the iron is about 3 years old now (and i use it heavily). I have gone through a few of the very fine 1.6mm pencil tips, but with such little material, that is to be expected, but they still last > 1 year.
Marko
Tue Jul 04 2006, 10:45PM
I definitely agree Weller pwns any other cheap iron in lots of things.
It can run forever, mine is about 2 years old and heavily used, it heats up in matter of seconds (no need of leaving it ON) and tip is very durable. My tip has a small hole on side some 10mm from top, but it doesn't affect performance at all.
Not to mention regulate-able temperature and other gizmos there.
Tue Jul 04 2006, 11:37PM
If you are seriously interested in electronics and plan to do lots of soldering in the coming years, invest in something good.
If you are poor, go for the Weller which is can entry level. If you have the money, get a Metcal which in my opinion are about the best out there.
If you are really hurting, then try for the cool-heat soldering iron they have on TV. . .
Michael W.
Wed Jul 05 2006, 12:14AM
I use mine almost everyday and for paying $15 it lasted a suprisingly long time. I probably should buy a nice good quality one, i'm always afraid of tv gimicky things. Can anyone vouch for the "Cold Heat" Soldering iron...EVR..Are you a owner of one?
Marko
Wed Jul 05 2006, 12:24AM
I saw that thng, and seems pretty big and unwieldy.
Normal irons are much easier to hold in hand and, I guess, it's no mach for weller or similar tip.
I think it is a great thing where portability is important..
Wed Jul 05 2006, 12:40AM
The cold heat soldering iron reference was merely a joke. I'm doubtful it even works at all . . .
