  • Guests: 75
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
My new sstc project
M.A.D.
Fri Sept 23 2011, 11:15PM Print
M.A.D. Registered Member #4052 Joined: Thu Aug 11 2011, 04:43AM
hello, I have decided to get into solid state, and I am now building Steve Ward's mini sstc.
I am going the following two changes to the design:
The secondary will be 1200 turns of 38AWG on a 2'' pvc pipe with a winding length of 6''.
Also I plan to build the coil in a faraday cage connected to RF and mains ground to isolate the coil's interference.
How long of arcs should I expect from this coil? because the primary is only going to be 5'' from the topload, also I've read that ground arcs turn your transistors into fireworks, so I need to make the cage of adequate size. Also will this provide enough sheilding to isolate the coil?
