  • Guests: 61
AIR SWIMMERS
Dr. Drone
Thu Sept 22 2011, 11:15PM Print
shades
Fri Sept 23 2011, 12:00AM
That cat leapt away pretty quick!
Chip Fixes
Fri Sept 23 2011, 12:21AM
Very cool! I may need to make one
haxor5354
Fri Sept 23 2011, 02:01AM
how do they make it so that it doesn't hit the ceiling yet be able to float above ground?
i've tried to make a helium blimp with fan propellors attached to it before, but it was always hitting the ceiling :(
AndrewM
Fri Sept 23 2011, 02:20AM
In practice I suspect its done by careful balancing and then careful selection of the video clips. I only watched a few moments, but few scenes lasted more than a couple seconds before cutting away.
They do the same thing with those commercials for those teeny tiny remote control helicopters - they show them landing on a pinhead but the reality is that they mostly just spiral out of control.
Chip Fixes
Fri Sept 23 2011, 02:43AM
haxor5354 wrote ...
It looks as though there may be a weight attached to the front
Fri Sept 23 2011, 04:27AM
I wonder if they are meant to sink slowly if not propelled. And if the propelling force vector is slightly upward as well as forward.
Forty
Fri Sept 23 2011, 04:28AM
if it's got neutral bouyancy, then a tiny fan on top and bottom could be used with an accelerometer to keep it from drifting about.
Dr. Drone
Fri Sept 23 2011, 05:31AM
shades
Chip Fixes
Fri Sept 23 2011, 08:07PM
Dr. Spark wrote ...
I won one on ebay for $38, so will see when it comes in mail….worse case can fly it into FATBOY at the next W.W.T. !
Good Job! I wouldn't mind if you posted details about it after it comes
