  • Guests: 78
MMC cap.
shady
Thu Sept 22 2011, 12:31PM Print
shady Registered Member #3597 Joined: Mon Jan 10 2011, 01:38PM
Hii, I found this cap. Link2 on eBay can i use it for MMC BANK ??!
Dr. ISOTOP
Thu Sept 22 2011, 03:20PM
Almost certainly not.
Matt Edwards
Thu Sept 22 2011, 03:58PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
You will want something that is rated for Pulse/HF. For example. Link2
Goodchild
Thu Sept 22 2011, 04:29PM
At $8 a cap you can buy 950C or 942C or 943C caps from CDE.
EDIT:
I just looked at the datasheet a little closer and they are indeed not suited for tesla coil operation. The peak current rating is only a couple of amps. Where most of the CDE 940C series are hundreds of amps.
Herr Zapp
Fri Sept 23 2011, 09:16PM
Shady -
Absolutely not, those caps use a polyester (aka Mylar) dielectric that has a high loss factor at high frequency. They will quickly overheat and fail internally.
Common low-loss dielectrics include mica or polypropylene. For MMC use, film/foil capacitors using self-healing "hybrid" construction (film/foil/metallized film) have been proven to be the best choice for spark-gap Tesla coil use. If you can't find peak and RMS current ratings for the capacitor you are considering, forget it.
The most widely-used and well-proven MMC caps are the Cornell-Dubilier 942C series.
Herr Zapp
shady
Sat Sept 24 2011, 09:58PM
wat a bout this cap :
R75 MKP
.47 micro K 1000Vdc
RD QA11009
can i use it for MMC ?
Dr. ISOTOP
Sat Sept 24 2011, 11:12PM
shady wrote ...
R75 MKP
.47 micro K 1000Vdc
RD QA11009
Datasheet?
Probably not would be my guess.
The answer is usually "no" unless the coil is tiny or the cap is special.
shady
Sat Sept 24 2011, 11:31PM
here is the data sheet Link2
shady
Sat Sept 24 2011, 11:37PM
and here is another one Link2
Dr. ISOTOP
Sun Sept 25 2011, 01:45AM
Definitely not.
