  • Guests: 52
Tesla 811a coil finished
Patric
Sat Sept 17 2011, 03:36PM Print
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
My Tesla coil is finished! I wanted a coil that can work for hours, so nothing is forced. The 811A can slightly turn red on maximum power, and the capacitors do slightly warm up, but no harm is done, even after one hour of working. See the power-regulator with the triac, it works perfect (not as expected tongue). It regulates the primary from 120V to 200V, and the output then gives a spark from about 2mm to 10cm. (The max and min values of the potentiometer are for regulation from 0 to 220V)
1316273605 2899 FT0 Teslacircuit
PS: - the lamp in the regulator is the primary of the microwave transformer. mistrust
- the 3 switches in the movie are to soft-start the 811A
The making of:
http://www.youtube.com/watch?v=H7nivw7zxNM
The result:
http://www.youtube.com/watch?v=Mp721VgxWQI
RogerInOhio
Sun Sept 18 2011, 11:42PM
RogerInOhio Registered Member #1034 Joined: Sat Sept 29 2007, 12:50PM
Very nice tube coil. Did you find that the height of the tickler coil makes much difference in the output?
Patric
Mon Sept 19 2011, 06:36AM
RogerInOhio wrote ...
It makes almost no difference, but when it is too high, the coil does not start.
U4R1A
Tue Sept 20 2011, 02:09AM
U4R1A Registered Member #3505 Joined: Sun Dec 12 2010, 06:03AM
Looks good!!
Patric
Tue Sept 20 2011, 08:08AM
Thank you!
Tue Sept 20 2011, 04:56PM
It is a lovely sound from a VTTC, have you considered a staccato controller to run lower BPS at a higher voltage?
I would also like to see a video of the spark output from a single breakout point
Patric
Tue Sept 20 2011, 05:47PM
The metal ball is 10 cm (2.5 inch) diameter. The sparks are +/- 15 cm (6 inch) diameter. I can make the spark longer, but then the 811A turns red...
]teslalen.avi[/file]
Tetris
Wed Sept 21 2011, 12:26AM
You should add a shut off timer of about two hours, and put a piece of black plastic near the spark gap (to cover it because it is too bright), so that you could fall asleep to the pretty sparks and the wonderful noise! Your coil produces the most pleasing noise from any Tesla Coil I've heard. I should build one... but I can't even get a spark gap coil to work ROFL. But very nice coil! I like how the sparks appear to "spin" as if it's on a rotary disk.
Polonium210
Wed Sept 21 2011, 02:43AM
Polonium210 Registered Member #3450 Joined: Sun Nov 28 2010, 05:01AM
HighVoltageChick wrote ...
Spark gap??? You must mean the vacuum tube?
Patric
Wed Sept 21 2011, 07:47AM
Thank you! In fact, it is a rotary disk!
1316591233 2899 FT124510 Rotary
