  • Guests: 74
Secondary Coil Question
Electrix
Wed Sept 14 2011, 09:26PM Print
Electrix Registered Member #4060 Joined: Sat Aug 20 2011, 04:53PM
After I wrap my secondary can i cover the winding's with tape, clear spray, or a putty? And if i did would it affect the output I'm assuming no but I'd rather ask the experts :)
Matt Edwards
Wed Sept 14 2011, 09:40PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
You can use a spray on enamel or varnish. I prefer epoxy myself.
doctor electrons
Wed Sept 14 2011, 09:58PM
Coating it will change its resonant frequency verrrrryyyy slightly. Not enough to be concerned about though.
I use a product called polycryllic. It dries clear, never yellows and cleans up with water. Once your coil is in tune,
after its all assembled, coated and dry, there will be no affect on your output.
Matt Edwards
Thu Sept 15 2011, 01:04AM
Here is what I use. Works great and is sold at most hardware stores. One coat is extremely thick. Link2
Maurizio Valvo
Thu Sept 15 2011, 10:13PM
Maurizio Valvo Registered Member #3219 Joined: Mon Sept 20 2010, 09:06PM
I have used an isolating spray for PCB boards (RS 569-290), but I got some bad blistering: I don't know the cause, maybe I sprayed to close to the secondary. The coil is working fine, I think there is no impact on performance, but probably I wouldn't use a spray again.
1316124822 3219 FT124394 Dsc00769 R
Fri Sept 16 2011, 06:11AM
Spray is about the worst you can use for secondary coils, I have had it crackle and its only very thin layers, so many are needed to give the same isolation a good varnish or epoxy coat would do.
Remember to have your secondary rotating when your coat it, also when it dries, this insures a even coating.
