  • Guests: 38
Secondary Coil
Electrix
Mon Sept 12 2011, 04:05AM Print
Electrix Registered Member #4060 Joined: Sat Aug 20 2011, 04:53PM
My secondary has like 1 or 2 loops that ended up overlapping among about 1200, will this ruin it :?
EDIT: Title corrected by moderator -MadsBarnkob
Herr Zapp
Mon Sept 12 2011, 04:50AM
Electrix -
Are you sure you're not talking about your secondary coil, rather than your primary coil?
And if by "loops" you mean overlapping turns on your secondary coil, then yes, this is usually a fatal defect.
As a last resort you can cut out the overlapping turns and try to make lap-splice, but no matter how it's done it will look pretty ugly.
Herr zapp
Electrix
Mon Sept 12 2011, 09:31AM
That's frustrating looks like ima remake it :/
Dr. ISOTOP
Mon Sept 12 2011, 05:12PM
I don't think there's anything wrong with overlapping turns...one crossed turn is not going to arc over.
