  • Guests: 30
Lyonel Baum (77)
Mattc1886 (17)
01/09 RickR (18)
01/09 TheBoozer (58)
01/09 invader (50)
How does the primary coil affect fans below it ?
hvdude
Sun Sept 11 2011, 12:51PM Print
hvdude Registered Member #4077 Joined: Tue Aug 30 2011, 11:40AM
I got two AC (line current) muffinfans under my primary for the sparkgap. How much will they be affected by the primary coil, sending back alot interference ? Should i have a filter connected before the outlet ? Problem is i only got one filter for the powersource and i use a variac so if i hook the fans up too it they will throttle with the power output.
How much clearence distance is recomended for "items" below the coil ?
