  • Guests: 25
01/13 si2030 (62)
What to do with 6 printers?!
Chip Fixes
Wed Sept 07 2011, 12:28AM Print
I kid you not. My family has 8 printers, I hooked the best one up to the wireless network and I gave one away but I still have 6 left. Anyone know of anything useful I can do with them? they're regular inkjet printers.
Forty
Wed Sept 07 2011, 01:21AM
modify 1 to accept copper clad boards
use 2 or 3 to make a mini cnc machine
use the rest to build some robots or just for parts.
the metal rods inside make pretty good coilgun projectile material. the motors are all pretty powerful and quiet. the power supplies might be able to run on their own depending on the design. watch out for the "dock" that the ink carriage goes to for cleaning and the cotton mat that's usually below it as they'll be all gummed up with ink.
Chip Fixes
Wed Sept 07 2011, 02:34AM
Forty wrote ...
Ah thank you! I really like the CNC machine idea! Do you (or anyone else) know of any good starting points? I haven't done a google search yet but I bet instructables might have an article or two
Forty
Wed Sept 07 2011, 02:48AM
owning and knowing how to program an arduino would be a good start. then i'd check out instructables for ideas.
Wed Sept 07 2011, 07:51PM
RepStrap maybe?
I made a silly mistake and only saved the rails with mine, should have also saved the sleds and associated hardware.
On the flip side, 4 identical rails ought to be fine for a Z axis at least, but use low melt alloy or Shapelock as the axis mounts.
-A
Turkey9
Wed Sept 07 2011, 08:14PM
Salvage the steppers, belts, pulleys, power supply, rails, other sliding hardware... There will be darlington array chips for the steppers...
There are a very large amount of articles, build-alongs, blogs etc. dealing with making a cnc. If you want to make a very small one for cutting foam or soft plastics you will probably just use the steppers and build everything else yourself. Printer steppers can't handle much load for machining metal and can't even do foam and plastics to that great of a tolerance.
A interesting option might be a laser cutter. You could fix a strong laser diode where the printer cartridge sits and modify the paper feed mechanism to move the work piece around. You would have to make your own stepper driver circuitry but you can find open source cnc software that you could use to do the actual control.
Thu Sept 08 2011, 12:13AM
Some inkjet printers have an optical encoder ribbon parallel to the rails, with a detector unit on the sled.
That lets them know the X position more accurately than depending on a stepper motor drive train.
(In fact, they often use a regular brushed DC motor for X motion, with better price/performance than a comparable stepper).
Those ribbons can be used as coarse diffraction gratings.
Put one in front of a laser pointer, to produce a series of closely spaced dots on the wall.
Put one in front of a computer projector that's showing one or more narrow lines,
and you can learn about the projector's output spectrum.
