  • Guests: 70
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Looking for "good" bus caps for DRSSTC
Matt Edwards
Mon Sept 05 2011, 08:19AM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Hello all,
Looking for some bus caps for my DRSSTC. Something suitable to create a doubler for the bridge. I will be using 140v input and cm150's.
I am thinking 450v(+) 2000-4000uf(+)... (feel free to correct me if my values are way off)
pauleddy
Sat Sept 10 2011, 01:51AM
pauleddy Registered Member #2909 Joined: Wed Jun 09 2010, 12:31AM
i have a few 400v, 1700uf ones, if that would work.
Sat Sept 10 2011, 11:02AM
If you are using a doubler, the caps need only to be rated at sqrt(2)*input AC voltage, in your case 200V caps are OK, 250V would be better but 400V is way overkill.
