  • Guests: 29
VTTC resonance theory
Sun Sept 04 2011, 09:19AM Print
Hello,
I am testing a tube coil and the calculations are conflicting with the reality. The calculated resonance of secondary coil with a topload and primary in place, is 600 kHz. I wound the primary so that the tank cap resonates with the primary coil tapped on the outermost turn at 450 kHz.
Then I wired up the circuit on my table with the primary tapped on the outermost turn, and turned it on. I was surprised to see that the coil makes pretty big sparks, the same length as the secondary winding. However after I checked the running frequency, I was surprised even more - the tank oscillates at 363 kHz !
How is this even possible that energy transfer happens so far from resonance? Why the primary tank oscillates so much lower than calculated?
Sun Sept 04 2011, 09:32AM
you are hitting harmonic wavelengths perhaps...
Sun Sept 04 2011, 09:56AM
The primary waveform is a sine wave which has no harmonics. The secondary can only be excited at its odd harmonics, so 3*f0, 5*f0 etc. So I think this isn't the case...
Maybe the coil works in this mode just as a normal non-resonant transformer?
