  • Guests: 33
Halogen lamp plasma speaker!
Xray
Sat Sept 03 2011, 02:12AM Print
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
I discovered something rather amazing that I wanted to share with my high voltage friends. After building my flyback driver Link2 I started to experiment with plasma speaker designs. I tried the traditional spark gap (long, thin arc) which worked fairly well, but I wanted to try some unconventional designs to see if I can get better (louder) audio output. In my research, I found some very old papers that describe a plasma speaker made from a quartz tube with a metal central electrode, which is surounded by a grounded metal housing. The h.v. power supply was amplitude modulated at audio frequencies, and the quartz tube was mechanically fitted to an exponential horn which amplifed the sound. Well, I got the idea of using a 100 Watt halogen lamp as the speaker transducer, and it works! (see photos below). I tried applying 120V to the lamp in order to see if that made any difference, but it did not, so I run it without heating the tungsten filament.
With the halogen lamp mounted in its holder, the reflector actually strengthens and directs the sound just like a regular speaker! It's actually fairly loud and sounds pretty good, although there is some noticable distortion when playing music. When playing only voice, the sound is loud and clear, and it rivals any regular paper cone speaker of small size! The only negative issue with this design is the production of ozone, and there's a LOT of it! After running this "speaker" in my shop (about the size of a 2-car garage) for about 15 minutes, the odor of ozone was overwhelming, and I had to open up the doors and windows to air it out!
I noticed that I got best sounds when the frequency and modulator DC voltage were adjusted just right. Too much or too little voltage, or if the right frequency wasn't set, then the audio quality and/or amplitude were very much degraded.
Here are some pictures:
1
2
3
4
Sat Sept 03 2011, 02:49AM
Are the two loose metal tubes always at the same potential due to that wire bridge?
Xray
Sat Sept 03 2011, 03:03AM
Patrick wrote ...
Yes. I would have used one long tube, but the lamp has a little evacuation stub that protrudes out the center of the glass envelope, and therefore I was not able to use one long metal tube. The glass stub is in the rear, and so it does not show in the photos.
I probably should explain about the TIP41C transistor that's just hanging on some wires in the picture. Originally, the DC regulator was just a NPN power transistor, and I fed the modulation into its base with an audio transformer. But I needed to turn the volume on my radio way up, to the point of distortion, in order to get good volume output from the plasma speaker. So, I added the TIP41C transistor in a darlington configuration which gives the modulator circuit much more gain. I plan to mount it on the circuit board so that it looks more professional instead of like a newbie hobby project! cheesey
Chip Fixes
Sat Sept 03 2011, 03:26AM
That is very cool! Thanks for sharing!
