  • Guests: 51
The evils of Li-Polymer cells
Wed Aug 31 2011, 08:22PM Print
Yup, as if we didn't need reminding how dangerous Li-Polymer cells can be if something goes wrong.
Yes they can work well, but the slightest defect that ordinarily would never cause a problem can result in a devastating fire which can run out of control in seconds.
This particular bad cell had a slightly higher self discharge rate which suggests to me an internal short under full charge was the cause of failure in this case.
Old cells are particularly prone to this because it can happen due to the internal structures changing shape over hundreds of discharge/recharge cycles.
Once bought a model pack on Ebay where the centre cell had failed, even though the seller charged it upon receipt it was sitting down at 8.2V instead of 12.
I wonder if it would be sensible to advise all 4HV'ers not to experiment with Li-Po or Li-Ion cells but to switch straight to phosphates on the basis that they fail safe.
-A
#include "sticky_topic_please.h"
Forty
Wed Aug 31 2011, 09:11PM
i'm guessing the phosphate ones are more expensive and have less energy density? In the future I'll be buying some rechargeable batteries for fast charging portable coilguns. haven't decided what type to use yet.
Adam Munich
Thu Sept 01 2011, 06:49PM
Nevermind the fires, these lipos can supply huge currents, blowing up every part in your project if something fails.
Thu Sept 01 2011, 07:46PM
But the power/weight and power/volume are so good
in return they need care.
The ability to deliver high currents (capable of causing fires etc.) is another benefit !
