  • Guests: 44
how to use a pentode as a triode?
alf
Wed Aug 31 2011, 12:06PM Print
alf Registered Member #3925 Joined: Fri Jun 03 2011, 10:50AM
hey,
i was gonna use these tubes Link2 in a vacuum tube tesla coil, but they are pentodes, and i wanna use this circuit Link2 so where do i connect the extra grids, so i can use it as a triode?
thanks. Alf.
Wed Aug 31 2011, 12:25PM
1) Connect control and screen together, ground suppresor grid.
2) Build a dedicated supply of a few hudred Volts for the screen (use a limiting resistor in series), put feedback to the control grid and ground suppresor.
3) (Experimental) Ground control and suppresor grids, feedback only to screen.
alf
Sat Sept 03 2011, 11:49AM
Dr. Kilovolt wrote ...
okay. thanks, how do i know which grid is the control grid, which is scree, and which is suppressor?
the tube just says grid 1, 2 and 3.
and also, will this tube will work as well as the 811a in the vttc circuit? (its voltage and current ratings are correct)
thx. Alf.
Tetris
Sat Sept 03 2011, 06:48PM
Take a random numerical prefix and mash them with the suffix -ode. Diodes are confusing enough (but usage straightforward).
Sat Sept 03 2011, 07:55PM
alf wrote ...
thx. Alf.
The grids are numbered in order away from the cathode.
First is the control grid, or g1 for short, closest to the cathode.
Second is the screen grid, or g2.
Third is the suppressor grid, or g3.
As for the last question, valves work best, and are most reliable, when they are set up using the datasheet values.
alf
Sun Sept 04 2011, 11:15AM
ok thanks, so id have to redesign this circuit? Link2
Sun Sept 04 2011, 12:11PM
alf wrote ...
The design ratings for an 813 self-rectifying Class C oscillator are given on page 2 of this datasheet here:
Read down the ratings in the Self-Rectifying Oscillator or Amplifier - Class C Maximum CCS Ratings section, and have a look at the OO footnote flagged on the AC grid no. 2 (RMS) line. I suspect this may be more trouble than you had bargained for.
Someone is bound to suggest strapping g1 and g2 together, but I have no comment to make on that.
