  • Guests: 51
Aluminum foil on table
axelro
Mon Aug 29 2011, 09:52PM Print
axelro Registered Member #3640 Joined: Sat Jan 22 2011, 12:16PM
In some Teslathon pictures, I noted the tables are covered in aluminum foil.
Is this just protection of the (wood) tables against strikes or does this have a meaning beyond, e.g. to lower the fres?
If so, by how much could this lower fres (just some examples, experiences)?
I am trying to figure out, if I should do the same - however, I am far away from having spark length to jump down to the table, so it's only making sense if it has another meaning.
doctor electrons
Tue Aug 30 2011, 09:42PM
Some people use it to measure what the coil is doing, sort of like an antenna.
It can be used with an oscilloscope to get a pretty good measurement. Being under
the coil it usually will not affect the free of the coil.
Maybe someone else can add some input as well.
Polonium210
Tue Aug 30 2011, 11:22PM
Polonium210 Registered Member #3450 Joined: Sun Nov 28 2010, 05:01AM
It is also used a counterpoise for RF ground.
axelro
Wed Aug 31 2011, 06:29PM
Thank you for the replies.
Instead of (just) asking I probably should have switched on my brain:
I now looked up the formula for plate model capacitors: C = epsilon * A / d
(with A being the size of the plates and d being the distance).
Given that, the aluminum size should make a significant difference, if the coil is on an non-conducting table. If one considers the concrete floor to be the one plate, and the flat projection of the topload the other plate, it should easily make a factor 2 in topload capacity. OK, that's a significant simplification, I know, and eventually neither is the concrete floor a good conductor nor is the wood a good non-conductor. Some result should be visible, if the aluminum is earthed (which it better be).
Opinions?
EDIT: I should simply try it - but I am lazy now. Perhaps during the weekend.
