  • Guests: 51
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
QCW DRSSTC buck converter
Dr. ISOTOP
Sun Aug 28 2011, 04:29PM Print
Does the buck converter modulating a QCW DRSSTC have to be a synchronous buck? I see that both Steve Ward and Eric Goodchild use one.
Goodchild
Sun Aug 28 2011, 06:39PM
Well it doesn't have to be synchronous. But if you use a regular buck you have to have some method to bring the voltage back down after a burst or when the OCD trips. If you don't do this the bridge will turn on with voltage on the bus and this can be catastrophic for your IGBTs.
A sync buck automatically brings voltage back down and recycles it back into the bulk C because of it's low side switch. A sync buck also can be more efficient then a regular one if built and tuned correctly.
