  • Guests: 39
Armstrong Oscillator/VTTC conceptual questions
christensenda
Sun Aug 28 2011, 03:10AM Print
christensenda Registered Member #3062 Joined: Wed Aug 04 2010, 02:07AM
Recently, I finished an 811A Class C series fed Armstrong Oscillator, and am under the impression that the nature of this oscillator is to put out relatively pure RF. I believe my coil runs around 450Khz. What is the resonant frequency which RF occurs at ?
On an unrelated note also, can VTTCs be made using a Hartley oscillator ?
Anyways its based of off steve wards design. single 811A, 2000VAC MOT. No level Shifter. 6.5" streamers. Tuned Primary, Tuned Feedback coil.
1314500862 3062 FT0 Gedc0127
Wed Aug 31 2011, 09:12AM
Isn't RF radio frequency?
The VTTC is a class C oscillator. There are probably more ways you can reconfigure it, but the principle of operation will always be the same. The Class C oscillator is the most efficient oscillator you can build with a single tube.
christensenda
Fri Sept 02 2011, 02:35AM
Yeah, I am referring to radio frequency, I was just wondering at which frequency does radio frequency exist at ? because I thought all VTTC oscillators put out pure RF but, I am under the impression that radio frequency is around 500-600KHz, and I dont think my coil is quite that high.
Are the spark characteristics generally all the same, regardless of the type of oscillator used ?
GrantX
Fri Sept 02 2011, 05:42AM
Actually, radio frequency generally refers to anything in the range of 3 kHz to 300 GHz. TV is usually transmitted (or was, anyway) in the UHF band which is around 300 MHz and 3 GHz, while the AM broadcast band is about 300 kHz to 3 MHz.
So if your coil runs at 450 kHz it is definitely in RF territory.
Nah
Fri Sept 02 2011, 07:46PM
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
harley, or a cathode feed back oscillator works fine
