  • Guests: 42
IGBT Modules and Gate protection
Polonium210
Sat Aug 27 2011, 07:03PM Print
Polonium210 Registered Member #3450 Joined: Sun Nov 28 2010, 05:01AM
I found these nice little IGBT modules on eBay.
Data sheet:
I plan on using them in a small full-bridge DRSSTC. Has anyone used these before, and how did they fair in Tesla Coil duty?
Also, I was wondering about gate protection? Should I use anything other than the gate resistor?
Thoughts, comments before I blow them up...:-D
Dr. ISOTOP
Sat Aug 27 2011, 07:17PM
Pulldown and zener on the gates should protect them fine during driving.
Goodchild
Sun Aug 28 2011, 06:47PM
Those are fast little IGBTs! Ive seen them used in the QCW before with great results.
About gate protection:
If you are driving with a GDT you should have some sort of TVS or zener from gate to emitter to protect against voltages spikes cased by the leakage L in the GDT.
If you are using a dedicated Si driver then the TVS or zeners are not really needed, but a 10k pulldown resistor from gate to emitter is very important to have! The reason for this is if your driver circuity losses power while the gate is on the gate can "latch" on because of the parasitic SCR present in IGBTs. The pull down is there to shut the gate off in the event that the gate driver losses power.
Hope this helps,
Eric
U4R1A
Thu Sept 15 2011, 01:52AM
U4R1A Registered Member #3505 Joined: Sun Dec 12 2010, 06:03AM
Would these IGBT's--> HGTG30N60B3D be any good of a SSTC?
Polonium210
Thu Sept 15 2011, 03:14AM
U4R1A wrote ...
Yes, these would be fine. I would run them at 400VDC.
