  • Guests: 46
Why you shouldn't buy cheap plug strips
Thu Jun 29 2006, 08:04PM Print
Hi all.
This is what happened to my plug strip. Hint:- Don't unplug stuff when its on next time :)
-A
1151611491 96 FT0 Plugboom
Thu Jun 29 2006, 08:09PM
Actually, you should probably rename the thread to
Why you shouldn't unplug stuff when its on.
instead.
Thu Jun 29 2006, 09:35PM
Well had it been made with any quality he could plug stuff in when it on...
I had one with the oposite problem. If you used the switch on it, it would blow the fuse in my amp angry The amp was a rackmount stadium one, so no on/off switch on it, and the crappy switch made some noise or something that caused the fuse to vaporise in the amp. Hint:- Always plug stuff in when it is on next time wink
Avalanche
Thu Jun 29 2006, 11:21PM
Ouch! I have a cheap plug strip under my desk, and it does some weird things sometime. You have to really hammer the plugs in as well, because of the tackyness of the interlock. Sometimes I look at the neon and it's on, other times it isn't neutral
Also I don't see any reason why you shouldn't be able to unplug something when a plug strip is on, unless it's a cheap plugstrip, so I think the thread title is quite relevent tongue
Fri Jun 30 2006, 04:46AM
Cesiumsponge Registered Member #397 Joined: Wed Apr 19 2006, 12:56AM
I had the same experience with the difficulty in inserting a plug on some powerstrips. It seems like you need to "break in" the receptacles first. Seems to dissapear after the few first insertions...kinda like "unit is used if plugs fit receptacle without a battle" warning.
Richy
Fri Jun 30 2006, 11:48AM
Richy Registered Member #121 Joined: Fri Feb 10 2006, 12:39PM
Years ago in my grandparents old house they had wall sockets with no on/off switch and very old bar heaters also with no off switch. Every time you unplug them there would be a flash of light as it arced, I always thought that was a little dangerous cheesey
Richy.
Marko
Fri Jun 30 2006, 12:23PM
How do 'sockets with on/off switch' actually look?
(OK, I saw some IR controlled ones)
Fri Jun 30 2006, 03:46PM
Dont most of the ones in the UK have a little switch in them?
Marko
Fri Jun 30 2006, 04:06PM
Haha, here we'r stuck deeply in 20'th century.
I tought these were USA outlets, and UK were also 'european' Link2
(220V)?
Avalanche
Fri Jun 30 2006, 05:05PM
The USA sockets always crack me up, because they look like this smiley but on your wall : suprised
In the UK all new sockets are switched, and some are fused as well like the ones in my kitchen :
1151687096 103 FT12311 Av Wall
