  • Guests: 54
Surplus Store Shopping
currentkills91
Thu Aug 25 2011, 09:25PM Print
So my grandma was nice enough to drive me to AX-MAN SURPLUS in Fridley today. I originally had gone there to find a motor to make a winding jig to turn my new tesla coil secondary while I poly coat it. In the end I ended up with almost 50 dollars of stuff I have no idea what im gonna do with. (:
Now with it being a surplus store the items aren't exactly new, but they are are in extremely good condition (:
1314306791 3831 FT0 Dsc01533
The big blue caps are rated for 4400uF at 300VDC - $14.00
The little caps on the left are rated for 450uF at 200VDC- $7.00
The little caps on the right are rated for 1400uF at 100VDC - $5.90
The two black things are wall plugs, with a fuse and switch - $3.00
Bag of heatshrink tubing - $3.95
50' ethernet cable - $9.95
10 - 1.2K 5W 5% ceramic? resistors - $1.00
A small glass jar with lid - $0.35
1 - 3V 1300mAh lithium battery - $0.95
10 - .68uF 25VDC tantalum caps - $1.00
2 - .68uF 100VDC WIMA caps - $0.30
doctor electrons
Thu Aug 25 2011, 09:43PM
SCORE!!
edit....
SSCOOOOOORRRRREEEEEEE!!!!!!!
currentkills91
Thu Aug 25 2011, 11:18PM
There's so much more there too, i'm going back tomorrow to get another batch of items (: I didn't even make a dent in the supplies they had for the things I took. They've got a bunch of tiny little caps for $0.10 - $0.25 i'm gonna grab as well. I'll post pictures tomorrow :)
Forty
Fri Aug 26 2011, 12:57AM
look for some higher voltage caps and some mkp caps. those are always nice to have. any sort of power supplies are nice too. those big lytics were a hell of a steal.
magnet18
Fri Aug 26 2011, 03:30AM
NOICE!!!1!
im jelly, oh so jelly
currentkills91
Fri Aug 26 2011, 05:27AM
Yeah, the highest they have is the 300VDC caps, and I think they have 3 or 4 left, but otherwise they have a ton of other components for next to nothing (:
currentkills91
Fri Aug 26 2011, 10:20PM
Went shopping again, and picked up way more than I did yesterday (:
1314395909 3831 FT123071 Dsc01538
17 different kinds of CDE capacitors in the baggies, ranging from .0015uF - .4uF. They're rated from 50VDC to 200VDC. Over 300 of them all together :D
2 - 12V, -12V, 5V SMPS modules
A bunch of relays
25 more of those resistors
36 - 0.68uF, and 1uF WIMA caps
8 - .1uF film caps
2 more of the 450uF caps
2 - 15000uF 15VDC caps
4 - 10000uF 16VDC caps
10 - 100V 3A diodes
I spent about 100 bucks for everything :p
Inducktion
Sat Aug 27 2011, 01:27AM
I know this is going to sound sort of wonky, but, would you be willing to trade for one of those SMPS modules? I need a negative supply and one of those would be fantastic!
currentkills91
Sat Aug 27 2011, 02:31AM
I'll warn you now, it's not capable of a whole lot of current. I'm not sure on the actual current, but I can test it out and find out for ya if you wish?
Inducktion
Sat Aug 27 2011, 03:40AM
Well, it only need be powering logic. So, a lot of current isn't really needed!
