  • Guests: 38
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
sold/ebay - Energy Storage Capacitors & Powerstat Variable Transformer in NY -
JC1
Wed Aug 24 2011, 01:57PM Print
JC1 Registered Member #3139 Joined: Wed Aug 25 2010, 02:20AM
Capacitors -eBay
Qty 2: 100uF @ 10,000 Volts : Non-PCB : Blue : Weight ~150 Lbs : $175/ea $300/Pair
Notes: Originally from a large Holobeam Nd:Glass laser I purchased and were ran as a pair with a PFN through an ignitron in that setup.
Qty 1: Aerovox PX30D50 : 176uF @ 10,000 Volts : ESI Max 100nH : Non-PCB : White : Weight ~150-175 Lbs : $250
Notes: From a canceled laser research project, I bought it along with a massive laser amplifier I sold years ago.
Powerstat Motor Drive Variable Transformer - Sold
Qty 1: Powerstat : 22Amps @ 120v x 2 (Stacked) : Slo-Syn Motor : Weight ~75-90 Lbs : $275
Notes: The Slo-Syn motor is configured with reverse and forward inputs which just require a simple 120VAC input via a switch or can be automated with a uC and Triac. There are cam driven limit switches which prevent over-driving.
For any of the above items, due to the weight I'd prefer the items be picked up or to meet near my location near Kingston, NY.
If you have any questions or want to discuss you can contact me here or via sarlock on gmail. -Jon
JC1
Fri Aug 26 2011, 01:51AM
Here are some photos of the Powerstat unit, I tried to attach them to the main post but it's not an option when you edit I guess.
1314323473 3139 FT122987 Dsc05531
1314323473 3139 FT122987 Dsc05533
JC1
Sun Sept 25 2011, 03:21AM
Powerstat sold, capacitors now on eBay, thanks folks.
